Type S RV6 Rear Sway Bar Settings
LunaticSM
Dstyle
NYC
LSM Integra Type S
Anyone else have experience with the rv6? I'm trying to decide if I should get one with the end links but am concerned about reports of clunking noises from it. Is it fine to just use the stock end links? How much stiffer is the lightest setting than stock?
Hind
Josh
Tampa, FL
I just installed mine. No rattles or clanks and I ordered them with the links. I'm using the middle setting. Headed to the track in a month...
Seems nice, but boy was it a pita to install.
Curious to hear your impressions. Did you take the car to the same track on stock suspension so you have a basis of comparison?
Rear sway is supposed to be an easy install...
Hind
Josh
Tampa, FL
This will be my first time with this car, so I won't have a before-and-after opinion, unfortunately.
I could install them quicker now, but getting the end links back into the lower control arms and lining up the holes is what was terrible. I had to use a two-jack method recommended by this video.
I had the same problem when getting mine back together. If I remember correctly it was a beast. Then, when we got load back on the wheels, the sway was slightly twisted, so we loosened up the subframe bracket bolts and the bar settled itself. Then we torqued the brackets back down and all good. We had to put it on the alignment rack and raise it up, so we could work under it while loaded, to get it all squared away.
Yes, this is correct.
A typical sway bar with the car's weight on all 4 wheels should be under zero preload. The final torque down for the bolts should occur with weight on the wheels.
Yes you can tune preload with bars and adjustable endlinks, but unless you know what you're looking for specifically, it's not worth the effort.
I'm curious as well to see what people's results with a rear bar are. I found this car to be pretty neutral at higher speeds to very oversteer prone at lower speeds. If you've lowered your car or dramatically increased front camber without ability to adjust rear camber, I bet the rear bar would be helpful. With primarily stock alignment and height, it would be nice to have a bar that can adjust from 25% softer to 25% stiffer.
LunaticSM
Dstyle
NYC
LSM Integra Type S
Ordered an Rv6 RSB and End Links last night....
I think my end links have developed a clunk sound. Very loud especially after a car wash. Sounds like a refrigerator compressor when you move a mini fridge around. I only hear it a lower speeds and rough roads.
it might just be that one is loose. I had that issue originally as well. Or at least something is loose somewhere in the suspension. Have you checked everything yet?
Hind
Josh
Tampa, FL
Went to HPDE event at road atlanta and car drove great. However my sway bar is making the clanking noise at low speeds over bumps. I'll get the car in the air soon to look at it...
