Break-in oil?
drysol
MI
I was talking about changing the oil in my ITS after the first 1000 miles but the service manager at the dealership immediately stopped and insisted that I wait for at least 7000 miles before doing an oil change. He explained that the break-in oil has graphite and that it needs to seep in. He didn’t really provide any technical reason for waiting until it reaches 7k miles. To my knowledge, 1000 miles is more than in enough for “break-in” period and most would suggest changing the factory oil.
Here for any suggestions or advice on this topic. Do you guys know about this break-in oil Acura is using on ITS?
bvanlieu
Lehigh Valley, PA
There have been times when more moly was in a factory fill, which arguably helps with engine break in as there is a little bit of wear over time.
At this point, there seems to be nothing special about the factory fill as UOA shows no unusual moly levels. Factory fill is a 0w20 synthetic, that I would simply change when you wanted to. Some want 1K, some 5K, some don't care and changing when the light tells them.
Me personally, I dropped it at 4K as I don't really like to do extended oil change intervals without some data on how that engine performs with that lube. I drive a good amount on the highway so once every 6mo changes will be in order for me most likely as I DIY and like to work on my cars.
chopsuey34
Michigan
2025 Civic Si
Relevant thread on CivicXi:
https://www.civicxi.com/forum/threa...as-any-benefit-to-keeping-it-in-longer.54128/
Summary:
1) Honda engineers have debates among themselves whether it is necessary to change oil at 1,000 miles or 7,000 miles. There is no official Honda consensus about changing oil early or not.
2) There is no such thing as special break-in oil. The oil is normal Honda OEM, but will contain elevated moly levels because the engine is coated with moly grease during production. Moly will break down into the oil as the engine runs and will be present for the first few oil changes.
(to anyone who says differently, find me a distinct OEM part number. It has to exist if Honda is using a special break-in oil from the factory)
3) Some Honda engines are coated with moly lube during prodution and some aren't and it doesn't seem to make a difference.
4) Doing an oil change at 1,000 miles won't help nor won't hurt your engine.
Honda's recommended break-in period is 600 miles per owner's manual.
JesterTuned
FL5 Type R, S2000, Ram TRX
Summary:
This^
I personally changed mine at 1K miles and then every 3-4k miles after because I like to keep fresh oil. Car has been flawless so far even with track days. I did bump up to a 5w-30 since the factory recommendation is too thin in my opinion and only recommended for fuel efficiency reasons.
scooter
Malcolm
I have been impressed by how consistently the dealerships say to wait until the service light comes on. I maybe naive but I can’t imagine their agenda is just to avoid an early free change. With 3k miles in nine months oil still looks clean/clear so I will wait atleast until I think oil’s clarity diminished. Enjoying the moly lube!
lumper
2007 Nissan 350z
IMO even if they have a break in additive in there, changing your oil after break in has shown metal shavings and sludge from baskets and silicone etc.. so, getting it out asap to me makes good sense.
I changed my break in oil at 1500 miles and changed it to Amsoil full synthetic 0W/20 and now, I am at 4k miles, when I hit 5k, I'll do the second oil change.
The longer you wait to change your oil, to me, the more potential for wear and or damage.
PRDE5
Chicago Burbs
24 Integra Type S
Debating about engine oil and engine oil change intervals is almost like taking about politics
bvanlieu
Lehigh Valley, PA
Nah...unlike the current US race, there are more then two extremely qualified engine oils out there that will do great in our cars :p
Oil geeks of course debate this, the only thing we can say with conviction is you won't hurt anything if you choose to change early as there is nothing helping with break in.
drysol
drysol
MI
Im just gonna go with this. Thanks for your suggestion!
AdreeN
Andrew
Toronto
2025 ITS
I'm picking up my ITS next month, and this is one of my painpoints, as I want to have this for as long as i can.
Probably going to follow the 1.5k/5k - 1st/2nd oil changes, but what about RPMs for break-in?
For example, do i keep revs under 3k rpm under until after first oil change?
Or under 3k for first 600 miles, and start ripping it until 1.5m/first oil change?
bvanlieu
Lehigh Valley, PA
From my original response, I have seen more data that support the FF is is the Type 2.0 oil based on its add pack which does include high moly. Its a good oil and I would not have any issue keeping it in there as long as you want for a street application.
Given that its not the ho hum Honda synth (phillips blends it for honda) I am of the opinion to leave it at least 3K/6 months.
As for driving, there are many schools thought. Most agree vary RPMs and loads, don't be afraid to give it the beans mid range and shift at 4/5/6K as you drive the first few hundred miles.
You do not need to keep it under 3K RPM. Drive with mechanical empathy.
If it makes you feel better, wait until 500+ to see the redline shift now notification :D
Wolfman
Dalton
San Diego
I did my first oil change at like 20% which was around 6500-7000 and they told me it was a little early but did it anyways. I am coming from wrx sti world where I did it religiously at 3k or 6 months because that car used all the oil lol
Idk if I am crazy but the butt dyno felt the car run better after the first oil change.
Could be placebo tho
CAN_ITS_ABP
James
Toronto ON
what about if you park your car for the winter? You can leave it in for a few months and then change it in the spring. I believe the manual says that it's good for up to 1 year (if I remember correctly)
