Nivek2slick
Kevin
La habra ca
Acura Integra type s
Thanks bro, I appreciate it. I've had eibach springs(Sportlines and Pros) on pretty much most of my cars. The streets here are riddled with massive potholes and uneven payment. The h&r springs are perfect for this area. Otherwise I would have opt for the Eibach Sportlines lol.
I attached the FB group below 👍
15mm front is perfect, 15 mm back would be good, just not quite flush. Some do 20mm on the back as the oem setup was a slightly narrower track on the rear vs. the front. 20mm evens it out.
That being said, I think 20mm may be too much on the rear, unless you had wider tires. If I had it to do over again I think I would go with 15 all around. Not sure I can describe why, I think it just looks a little to far out when looking at the car from 20 feet behind it. Don't get me wrong, still looks nice and beefy and well stanced, just something about it though...
Nivek2slick
Kevin
La habra ca
Huge shout out to everyone who has commented on other posts. Ultimately I decided to go with the H&R lowering springs and Bonoss 20mm (all around) spacers.
Major shout out to @NSXavier for the guidance, install + alignment. A member on here posted his video about his spoon install which he mentioned "DMV area." Perfect, I've been looking for pros lol.
IMO the ride quality is almost like factory and the bonoss spacers got the offset to just perfect. To be really honest comparing each setting: comfort, sport, sport+ from stock until now, it's a marginal difference if that.
If you're from the DMV and looking for a professional to work on your car be sure to hollar at him 💯🙏🏻
(Tried to upload a video showing the stance but the file is too large. Feel free to hit me up on ig (vlow714) or check out the FB group for it or PM me here and I'll send better photos 👍)
How much of a drop was it ? And where did you get them from looking online can't find
Nivek2slick
Kevin
La habra ca
Also do you know the difference between the two bonoss wheel spacers seems to be two different ones little confusing one being more then the other
vtecvlow
vtecvlow
James
The drop is ~0.8" f/r with no reverse rake.
I want to say I ordered it on Amazon? But it was cheaper off the websites (sorry not mucb help i dont recall).
At the time H&R didn't make it for the DE5 so I went with the FL5.
vtecvlow
vtecvlow
James
Not sure where you got "two bonoss wheel spacers" from in my OP. I mentioned they were same all around? Lol but if you're looking for the spacers I went with, they're 20mm spacers front and rear.
Nivek2slick
Kevin
La habra ca
Don't laugh but what is rake lol
Nivek2slick
Kevin
La habra ca
On the website there a selection of two different ones and from there u select size but there's two different price options regardless of the size
vtecvlow
vtecvlow
James
I would definitely contact them, some time has passed since I've ordered them until now. They're very good about responding to inquiries.
So having rake means front lower then rear and having no rake means looks all same
Yep or a reverse rake which front is higher than rear and seems to happen with Spoon springs and some other brands.
