So I figured out the issue, I needed to clear all connections to the Flash Pro first, then connect immediately with Torque and was able to read data. Sadly, it didn't provide much more information than my $10 BT adapter. It's still useful, you can display AFR and timing advance and a few other metrics, but sadly none of the temperature values I really wanted to see.
But yeah, would be much better if Hondata just directly supported AA, but with all the restrictions on AA/CP apps due to distracted driving, not sure it's even an option.
Are you using this for Torque?
https://github.com/agronick/aa-torque
ZeroGSR
2024 Integra Type S (LCM)
Same idea and install process, slightly different software. So it's odd because Hondata can display engine coolant temp, when I switch to Torque it's listed as one of the sensors supported but if I go through the live data it shows nothing is being communicated. Same thing as when I use a normal BT adapter. So it's some kind of communication issue.
Torque provides a generic listing of sensors. A custom PID would need to be created and mapped for additional sensors. Someone created one for a prius awhile back that would let you monitor the battery cells and other sensors.
ZeroGSR
Thanks, was able to add a few more using some PIDs I found on the Civic forums. Sadly still nothing that could show clear indications of timing pull from knock. At least I can monitor IATs and Coolant Temp directly.
I wish TEP looked like that ALL the time instead of just in direct light.
Artwork Bodyshop kit installed.
Acura Integra What did you do to your Integra Type S today? ๐Ÿ™‹๐Ÿปโ€โ™‚๏ธ IMG_0179
Acura Integra What did you do to your Integra Type S today? ๐Ÿ™‹๐Ÿปโ€โ™‚๏ธ IMG_0163
Acura Integra What did you do to your Integra Type S today? ๐Ÿ™‹๐Ÿปโ€โ™‚๏ธ IMG_0189
Acura Integra What did you do to your Integra Type S today? ๐Ÿ™‹๐Ÿปโ€โ™‚๏ธ IMG_0177
Acura Integra What did you do to your Integra Type S today? ๐Ÿ™‹๐Ÿปโ€โ™‚๏ธ IMG_0191
I dig it. Just subtle enough. Any modification needed while having the splash guards installed?
I agree, I didnโ€™t want anything extreme or to distract from the awesome design of the car.
Actually yes, & I shouldโ€™ve been specific about that. I made videos that I still need to edit & post to my generic YouTube page. I took a jigsaw to the corners of the rear diffuser & front splitter for clearance. At first I was going to cut the guards & slide them in, but this was easier & the kit is already made of black HDPE so you have to look very, very close to tell.
Acura Integra What did you do to your Integra Type S today? ๐Ÿ™‹๐Ÿปโ€โ™‚๏ธ IMG_0125
Acura Integra What did you do to your Integra Type S today? ๐Ÿ™‹๐Ÿปโ€โ™‚๏ธ IMG_0198
b0nb0n
Anthony
2024 Integra Type S, 1999 Civic, 1997 Celsior
Awesome thanks for sharing! Not bad at all, well done. Will be useful for folks who want to tackle the same in the future. :thumbsup:
I wish there were more aero options but this kit does look good. Not super aggressive and accentuates the ITS natural shapes.
