TPMS Question
East Coast
Do you need to get TPMS sensors when you get new wheels? or new tires? i've only had indirect TPMS before so i have no idea where the sensors even go, and at what point when you replace wheels/tires do you then need to get the sensors as well.
sorry this is all new to me.
Also no programmation needed. Sensors automatically connect to the car after driving for like 5 minutes.
East Coast
so i have a spare set of OEM wheels for my ITS- it looks like they came with the TPMS sensors already installed on them, which is cool. i ordered a set of all season tires for them so i was wondering what i needed to do once i put them on my car for my car to read from them.
so the car will automatically interface with them once i start driving? that's... convenient lol i had always imagined there were wires or whatever running to the sensors- i literally had no idea how the active TMPS was hooked up or worked
jquelch
Jason
Manhattan, KS
2024 Integra Type S - Apex Blue Pearl
Yep, just installed mine last night. You can watch them pop Into the tire pressure info display one by one as you drive. I just drove maybe 2 miles before all 4 got picked up and began showing the pressures.
Xcfool
Blake
Texas
Liquid Carbon Tech 6spd
Is this the same with an ASpec Integra so that we don't need to manually program a new set of sensors?
East Coast
wait i just want to verify, you don't need the TPMS sensors programmed to your specific car? i just got my all seasons mounted on my spare OEM wheels at a tire shop and they specifically asked me if the TPMS sensors had been programmed to my car because they won't work just with any vehicle- which makes sense otherwise wouldn't you be picking up signals from everyone elses' sensors in traffic?
mine are good because they were literally already on my car from the dealership but i might buy another set of wheels in the future and i need to know if i need to have acura or whoever program them for my car
As long as they are the correct part number and on or in the car it will work.
You might run into problem with aftermarket sensors. If you use the OE ones, you're OK. And if you wanna cheaper one, buy them at a Honda dealer. I put the part number in the other TPMS thread. Cheaper that way compared if you buy at the Acura dealer.
You were talking to some dinosaurs 😉
Early TPMS systems required a learn procedure with a special tool required to activate the sensor to send the signal while the car was in "pairing mode" (it was almost just like pairing bluetooth devices but required an additional 4 figure tool). Now that we have entered 2023 it is no longer necessary.
GTO
24 ITS, 17 BRZ
Just order OEM sensors part number 42753-T6N-E03 from your preferred online wholesaler. They run about $35 each.
I replaced the rims, tires and used the same 42753-T6N-E03 TPMS. When first starting the car, there was a (!) in the cluster then within a minute and without having to touch a thing, the new sensors were in sync and reporting pressure from all four wheels.
